1996 Ford Contour V6, Lower Brake Only Lights Not Working
JAMIECINCO
1996 Ford Contour V6 mileage: 59,000. When I step on the brake pedal, my brake light in the rear window goes on but the other brake lights do not. I have checked all of the bulbs and fuses and they all seem to be working properly. Any suggestions?
Feb 2, 2006 at 4:35 AM
CHEVY350GUY
  • 109 POSTS
is there power at the bulb? if not there could be a broken wire in the harness. trace the wires and test for power.
Feb 2, 2006 at 8:55 AM
JAMIECINCO
There is power in the bulbs. The running light part of the bulb is lighting, but the brake light part is not. I replaced the brake light switch, could I have intalled it wrong?
Feb 2, 2006 at 9:02 AM
CHEVY350GUY
  • 109 POSTS
not if the eye level light works. but with the brake pressed is there power? this is a different circuit from the running lights.
Feb 2, 2006 at 9:41 AM
