1996 brake lights
FORDCONTOUR
Brakes problem
1996 6 cyl
we tried changing the bulb in my moms car but no luck the brake lights do not work? can it be a fuse and if so where is the fuse she has millions of fuse boxes under her dash
Aug 17, 2008 at 10:39 AM
BLACKOP555
  • 10,386 POSTS
does the thrid brake light in the window work first of all?
Aug 17, 2008 at 12:31 PM
FORDCONTOUR
yes it does work. i tried all day with my mom's brake light but no success. she is 78 and cannot afford to send it some place so your help is appreciated
Aug 17, 2008 at 1:50 PM
BLACKOP555
  • 10,386 POSTS
since the high rise light is working but the lower brake lights are not working, its a good reason to suspect that the fault is located in the turn signal switch.
take and go to a junk yard to get the part that way you save the money. pretty simple to install just take your time.
Aug 17, 2008 at 2:14 PM
