1996 Ford Contour Transmission
1996 FORD CONTOUR
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
DUANE NORTON
What causes hard shifting from fiirst to second gear on an automatic, plus ovcerdsrive flashing?
Nov 30, 2009 at 5:34 AM
BMRFIXIT
  • 19,053 POSTS
OD light flashing is an indication of tranny trouble
check tranny fluids
should have the tranny module(TCM) checked for codes
Nov 30, 2009 at 6:25 AM
TRANSMAN1
  • 29 POSTS
Hello ,Are you sure the trans is shifting to second gear or revving high and shifting to third from first?Does it shift to fourth gear?Overdrive light flashing is telling you that it experienced some type of problem and needs to be scanned for codes.These transmissions CD4E is what should be in your vehicle are bad for braking 2-4 bands and that is why i asked if your sure its shifting all gears or skipping gears.
Jan 6, 2010 at 6:45 PM
