1996 Ford Contour Transmission Selector
105,889 MILES • 4 CYL • 2WD • AUTOMATIC
HIGHLANDPIPER
The Transmission Selector is stuck in Park. When attempts at manipulation is made, a clicking noise in the vicinity of the steering column is heard. The noise is remenecent of the clicking noise of a partially powered solenoid.
Jun 25, 2010 at 4:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for donating
if the gear selector will not move from park, it is often the result of a failed brake light switch or park/neutral position switch. check to see if your brake lights are operating when brake pedal is down.
Jun 25, 2010 at 5:49 AM
