1996 Ford Contour PCV valve
ROCKYWRX
  • 1996 FORD CONTOUR
  • 4 CYL
  • FWD
  • 106,000 MILES
Hello I have searched but can not find. Im looking to see where the pcv valve is, I bought the haynes manual but it only shows a picture for the 6cy not he 2.0. If someone could give me a link to a picture or diagram of where it is it would be greatly appriciated thanks in advance
Tuesday, April 15th, 2008 AT 3:04 PM
JS23
You can't reach it from the top. Jack up the car. Crawl under on your back while centered between the front wheels. Look up between the catalytic converter and the front of the engine and you will see the pcv valve about 10 inches up and out of reach. You will see the big end of pcv valve pluged into the engine, and a black rubber tube in the smaller end. The Ford manual says you have to take off the catalyitic converter to change the pcv valve. Fine Ford engineering at work here! I struggled for an hour to change it using real long pliers. But I think I broke the connector of a sensor that is right nearby and in the way. So I would suggest just leaving the pcv valve alone unless you know it is bad. Otherwise, if you take off the catalytic converter, all the rusty bolts will probably strip or break and then you have a bigger repair problem.
Tuesday, April 29th, 2008 AT 8:36 PM
