1998 Ford Contour PCV Valve
1998 FORD CONTOUR
TPAUL1
Engine Performance problem
1998 Ford Contour 4 cyl Front Wheel Drive Automatic
Need help finding PCV Valve to Replace? Thank you Tim
Nov 21, 2009 at 7:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the PCV valve is located behind the heat guard on the driver's side at the front of the vehicle. It's pretty simple to remove it by getting to it from under the vehicle. You can use a screwdriver to pop out the old one.
Dec 21, 2009 at 1:08 PM
