1996 Ford Contour Overheating
ROYALT50
  • 1996 FORD CONTOUR
  • 4 CYL
  • FWD
  • 148,000 MILES
I had my water pump and timing belt changed out twice. I still have an overheating problem. I'm riding without a thermostat in the vehicle. The mechanic said, he believe the head is warp or gasket is bad. I don't have any discoloration in my oil. This is an expensive job to repair the head. So what do you think. Help
God be with You
Saturday, October 25th, 2008 AT 10:53 PM
BMRFIXIT
  • 19,053 POSTS
I would also suspect head and or headgasket issue
a small test should determine if its for sure
do the headgasket test
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Monday, October 27th, 2008 AT 6:22 AM
