I would like to find out if their are any leaks or coolant in the oil.
If there is leaks then suspect a cracked or leaking improperly tightend coolant hose. Just replace it.
If you have foamy oil or oil in coolant or oil then suspect a bad head gasket.
If there is none of that then suspect a bad thermostat or a air bubble in cooling system.
SPONSORED LINKS
Sunday, October 21st, 2007 AT 7:53 PM
