1996 Ford Contour engine sluggish and stalls
STEVEFER
  • 1996 FORD CONTOUR
  • 4 CYL
  • FWD
  • 130,000 MILES
This car is very sluggish and stop and go traffic and if you try to drive normal the car will die you have to full throttle the pedal to get the car going I have changed the fuel pump, fuel filter, oxygen sensors, tps and I am not sure where else to go
Saturday, October 11th, 2008 AT 10:59 PM
BMRFIXIT
  • 19,053 POSTS
Check timing
check exhaust system and catalytic converter
check spark and coil for a good strong and blue spark
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, October 15th, 2008 AT 8:26 PM
