EDIS (DISTRIBUTORLESS) 2.0L
check fuses and wiring
Spark Check
Perform self diagnostic QUICK TEST(KOEO) to check for ignition-related fault codes, and repair as necessary.. If no fault codes are retrieved, check ignition system wiring harness for damage or loose connectors. Clean or repair connectors as necessary.
If wiring and connectors are okay, use Neon Bulb Spark Tester (D8IP-6666-A) to check for spark at each spark plug while cranking engine. If spark is strong and consistent at each spark plug (one spark per crankshaft revolution), ignition system is okay
SPONSORED LINKS
Sunday, May 3rd, 2009 AT 4:42 PM
