1995 Ford Contour tiiming
YAHYAHBWUY
  • 1995 FORD CONTOUR
  • 4 CYL
  • FWD
  • MANUAL
  • 170,000 MILES
I have a 95 contour gl 2.0 and I am doing the head gasket. I am confused about lining up the timing marks on the crankshaft and oil pan because when I bring cylinder #1(closest to passenger side) to TDC the crankshaft and oil pan timing marks are not lined up
Thursday, May 13th, 2010 AT 8:00 AM
  • 109,885 POSTS
Refer to the belt routing diagrams site on this page. It will identify where the marks go. Let me know if it helps.
Friday, May 14th, 2010 AT 7:20 AM
YAHYAHBWUY
  • 7 POSTS
I was using the diagram but the marks on the crankshaft pulley and oil pan do line up when cylinder #1 is at TDC
Friday, May 14th, 2010 AT 10:25 AM
  • 109,885 POSTS
Did you have the harmonic balancer off for any reason?
Friday, May 14th, 2010 AT 12:03 PM
YAHYAHBWUY
  • 7 POSTS
I took off the crankshaft pulley but then I put back on to align the timing marks
Friday, May 14th, 2010 AT 3:31 PM
  • 109,885 POSTS
Okay, I need to know something. Behind the pulley is the harmonic balancer. It is keyed and can only go on the crankshaft one way. Are there marks on that?
Saturday, May 15th, 2010 AT 10:44 PM
