1998 Ford Contour CAMSHAFT TIMING
R CELLIAN
  • 1998 FORD CONTOUR
  • 4 CYL
  • FWD
  • MANUAL
  • 100,000 MILES
I GOT A CODE P1383 CAMSHAFT TIMING RETARDED.
IS THERE A FIX FOR THIS?
IS IT THE SENSOR?
OR SOMETHING ELSE?
Sunday, January 6th, 2008 AT 5:22 AM
  • 31,937 POSTS
Hi there,
This just may be a faulty sensor, but you will have to get the (V.T.C) Variable valve timing control unit inspected, this is attached to the front of the cam shaft and operated by engine oil pressure, it is something that a trained technician should inspect for you.
Mark (mhpautos)
Sunday, January 6th, 2008 AT 5:53 AM
