1995 Ford Contour
CHRISTIANMOM2
  • 1995 FORD CONTOUR
Other Category problem
1995 Ford Contour 6 cyl Wheel Drive Type unknown Automatic 120, 44 miles
my heat hand on my car is on normal but it stay at a high normal and after I run my heater for a while there is like a smell of something smoking you have an answer?
Saturday, February 2nd, 2008 AT 5:11 PM
BMRFIXIT
  • 19,053 POSTS
Do you have a smoke inside the car
check under hood for leaks (oil---coolant)
if you put the heater on defrost does your front windshield fogs on you if so check/replace heater core
Saturday, February 2nd, 2008 AT 5:30 PM
