87 Bronco 100k on truck, 60miles on reman motor. I just had a reman mototr put in my bronco, since I got it back it has ahd no power at all, hit the gas and pop, pop but no acceleration, took it back they told me fuel problem so I replaced both fuel pumps, EGR valve, TPS sensor, Fuel pressure regulator, fuel filter, MAP sensor, ignition swich. When you spray carb cleaner in throttlebody the truck sounds and runs great. Any help PLEEEEEEZ!
SPONSORED LINKS
Saturday, May 20th, 2006 AT 5:45 PM
