1988 Ford Bronco cant figure this out
PDACK
  • 1988 FORD BRONCO
1988 Ford Bronco 6 cyl Four Wheel Drive Manual
I have an '88 bronco II it would just stall out once and awhile but start up soon after. I was going down a dirt road and it stalled but wouldnt start again. I got it home and it would run for a minute and then nothing for the rest of the day. Now it wont even do that. I get spark, both fuel pumps were replaced, fuel filter, fuel pressure regulator. I'm stumped, any help would be greatly appreciated. Please and Thank You
Monday, February 15th, 2010 AT 12:15 AM
Verify the fuel pressure by checking it with a fuel pressure gauge if its within specs and make sure the injectors are pulsing and its still getting spark if all okay-check the valve and ignition timing
Monday, February 15th, 2010 AT 12:52 AM
PDACK
I checked the fuel pressure, I turned the key on and it went up a little and then turned it off and on again and it went up some more untill it was up to temp. I have no clue what that means.
Wednesday, February 17th, 2010 AT 7:14 PM
What's the fuel pressure reading?
Thursday, February 18th, 2010 AT 9:54 AM
PDACK
The fuel pressure goes up to 45 and drops to like 35 while cranking so thats good. Im still getting good spark. I used a code reader and it said it has low throttle position sensor voltage but I dont know what that means or if that will stop it from running.
Wednesday, May 5th, 2010 AT 9:32 AM
