1987 Ford Bronco fuel issue
JEHUSAFAT
  • 1987 FORD BRONCO
Engine Mechanical problem
1987 Ford Bronco V8 Four Wheel Drive Automatic
i have a 1987 ford bronco with a 302 v8 I am having fuel issues I have replaced fuel pressure regulator ignition coil cap and rotor spark plugs and wires and have replaced fuel filter I have hooked up fuel pumps to swith so ican turn them on manually engine starts up fine when I spray starter fluid into intake I leave fuel pumps on while I start up with started fluid once fluid is gone engine sputters for a second then dies out
Tuesday, July 14th, 2009 AT 1:28 PM
DOCFIXIT
  • 18,828 POSTS
Have you checked fuel pressure?
Tuesday, July 14th, 2009 AT 1:39 PM
JEHUSAFAT
  • 27 POSTS
Have not had a chance to check fuel pressure bought truck about 15 days ago previous owner says that the pump it putting out about 40 psi but pump sounds like it is straining a bit
Wednesday, July 15th, 2009 AT 11:43 AM
