Ford Bronco Automatic Hubs Stuck Engaged Fix
SKATLIB
Just the other day i put it into four wheel drive and when i took it out my automatic hubs wouldn't release and they are still engaged i have no idea how to manual disengage them
Jun 25, 2007 at 7:52 PM
JWALTH02
  • 180 POSTS
There really is no way to disengage them. I had automatic hubs on my 92 bronco but I replaced them with manual ones after my first offroad adventure getting buried over the rear differential in mud. So it's either put it in and out of 4x4 till they release or just get some manual hubs.
Jun 26, 2007 at 1:00 AM
CEEBEE TAYLOR
I've watched video on this you have to drive 10 to 15 feet in reverse to fully unlock hubs
Feb 12, 2018 at 5:57 PM
  • 55,845 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Feb 14, 2018 at 2:50 AM
MISER26
trying to change a rotor, took cop off of the locking assembly, took off the outer snap ring, took off inner sap ring, still can't get it off, comes out as far as the outer snap ring grove is there somthing I missed?
Sep 5, 2019 at 3:41 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
auto or manual locking hubs?
MISER26
I have manual looking hubs, still having a problem
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1603.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_489.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_184.jpg
DONNY GURRUSQUIETA
I have a similar problem with the assembly but mine is auto. I was able to pull the hub assembly but as I pulled the it off, pieces of what appear to be a gear ring fell off. Have no clue what or where they need to be replaced. I stopped there and haven’t pulled off the spindle nut to get to the bearings. Does anyone have an exploding diagram that I can reference to see what this part is and order a replacement somewhere? Also maybe a procedure or link on how to replace the rotors since these are shot(original) :-0? Thanks!!
  • 55,845 POSTS
Here are the diagrams for the front auto locking hubs. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Suggested Repair
Shift out of 4WD and drive about 10 to 15 feet in reverse to unlock the automatic hubs, or cycle in and out of 4WD until they release. If they continue sticking, replace the automatic hubs with manual locking hubs.
Conversation Summary
A Ford Bronco owner reported that the automatic hubs stayed engaged after leaving 4WD and asked how to release them. Replies said there is no manual disengagement method and suggested cycling 4WD or installing manual hubs. Another user said driving 10 to 15 feet in reverse fully unlocks them, and an expert endorsed that advice. Later posts about rotor removal and broken hub parts were not fully resolved beyond diagrams for the automatic hubs.
