85 Bronco II V6 2.8 4WD: A few weeks ago after running for about 8 miles(20 mins) and shutting off and re-start the idle sticks and the engine runs fast( in drive without any pressure on gas petal will coast at about 30-35 mph . Checked engine , oil around gaskets and lower engine.Checked oil it read about a quart low. Put oil in it ran fine about 3 days. Now it starts okay somtimes and sticks after runing ,shutting off and re-start, sometimes starts with stuck idle and lets off after driving a few miles.Oil gauge reads normal, but the high idle heats engine and burns oil leaked causing it to smoke.Checked collant it's ok.Gauge reads normal.
Is this an oil pump problem, or maybe the idle speed control soliniod ? where is the idle speed control soliniod and how do I replace it?
May 16, 2007 at 4:55 AM
