1990 Ford Bronco Battery Drain
1. as far as the relay goes it sounds like it is doing what it is supposed to be doing it comes on the pump runs and realy shuts off pump shuts of right?
2.ok this is going to get a little more involved. will answer this more this evening. i'am at work now.NOS
Sorry - long story for a short question: Could sitting for so long affect the regulator?
and to answer your other question yes it is possible if the battery was down at the time of restart, it again could make the regulator do the same as i dicribed before.
one thing that you can try is charge your battery fully and on the altrernator there is a big plug unplug it and let it hang over night if you battery stay up then wa-la you'll know that it was the alternator if not were back to square one but it is worth a try sorry i know you need the truck but bud i'am not there so i can only tell you what i have experanced before. 8) NOS
I'll try the alternator thing tonight. Thanks again, NOS.
Suggested Repair
The fuel pump relay was already replaced and appeared to cycle normally. Fully charge the battery, then unplug the large alternator connector and leave it disconnected overnight. If the battery holds its charge, the alternator or its voltage regulator is causing the drain and should be replaced.
Conversation Summary
A 1990 Ford Bronco owner reported a dead battery overnight and thought the fuel pump kept running after shutdown. Replacing the fuel pump relay did not stop the drain, and the relay still clicked on and off normally. The expert explained the inertia switch and fuel-pump circuit, then suggested a charging-system problem, possibly from repeated jump starts. The owner unplugged the alternator connector overnight as advised and confirmed that this stopped the battery drain.
