1993 Ford Bronco Fan Chirp and Squeal
CHILIENOJADO
1993 Full Size Bronco. 5.8 Litre (351 ci) w/ac.
I have a constant chirp at start up.
A full squeel after running for about 1/2 hr.
I used a stethiscope on all the pullys except the fan clutch.
Everything is running smooth.
I removed the fan and fan clutch.
The spindle turns real hard but after a minute of turning it the spindle turns (almost) freely.
Shoud the spindle turn real hard at first and then loosen up?
Or should the spindle turn freely and then begin to turn harder.
As the motor begins to warm up, then become hot, it seems to me the clutch should engage more and more until it is fully engaged turning the fan at max.
Think I need a new fan clutch?
Regards...Ron L
Feb 16, 2006 at 9:02 AM
LOVESCARS
  • 359 POSTS
The clutch should engage the hotter the engine gets. This is a commonly overlooked item that can cause other problems that chirping.
Check the water pump?
Feb 16, 2006 at 12:45 PM
Suggested Repair
Confirm the fan clutch engages more firmly as the engine gets hotter, and check the water pump, a commonly overlooked source of chirping.
Conversation Summary
A 1993 Ford Bronco with a 5.8L engine chirps at startup and squeals after about 30 minutes. The owner checked the pulleys and found the removed fan-clutch spindle hard to turn at first, then nearly free, and asked whether a new clutch is needed. The expert said the clutch should engage as the engine heats and recommended checking the water pump.
