Have problems with stalling, mechanic changed the TPS and Fuel Injection computer module residing in firewall. Also, have a hesitation when stepping on the gas, idle or in gear. I changed the plugs, wires, rot, cap, fuel filter. Will idle fine, but will stall if put it in gear or attempt to start moving. Bronco will also stall, while idling, when turning the wheel left or right. Engine light comes on that points to fuel injection problem, but can you help further, is there anything you can suggest that might help us diagnose? Thanks.
SPONSORED LINKS
Monday, November 19th, 2007 AT 1:25 PM
