Hello, I have a 1988 ford bronco ii, 4wd, automatic, 2.9 v6, 30,000 miles on rebuilt engine. Bronco starts fine, runs good have intermittent hesitation/stalling and the check engine light will flash when this happens. I have replaced the distributor cap, rotor button, plug wires, spark plugs, ignition module, ignition coil, fuel pump relay and both fuel filters. I get two engine codes: 95-Fuel pump relay secondary circuit failure and 48 Loss of IDM. I can hear fuel pump come on and checked fuel pressure, it is 40 psi. Any help will be GREATLY appreciated. Thanks
SPONSORED LINKS
Sunday, April 15th, 2007 AT 12:15 PM
