I have an 81 Ford Bronco, 351m, 200k. I noticed a while back that my brake pedal was going soft and the truck wasn't stopping like it should, then the brake light came on. I pulled the cover off the fluid reservoir and noticed that the front (smaller) compartment was empty but the back was full. I also noticed that the booster had some fluid on it. I Assumed that I just had a small leak that I had let get so low it got air in the lines so I bled the back brakes and topped off the reservoir. The brakes have since worked better than ever but I don't know how to get the brake light to turn off. Any suggestions? Thanks for the help.
Oct 9, 2007 at 7:57 AM
