1981 Ford Bronco Sinking Brake Pedal
TEX0177
I have a 1981 Ford Bronco, 351m, 200K. Yesterday the brake pedal began sinking in more than usual when I stopped. The truck still stopped but not like it should. Then the brake light on the dash came on. I checked the fluid reservoir and the front compartment was empty but the back was still full. How can I determine if the master needs replaced or what the problem might be?
Sep 12, 2007 at 4:26 AM
MERLIN2021
  • 17,250 POSTS
Wich resv was empty? the small or large? The small is the rear large is the front, I would check for puddles after refilling with Dot3 At this truck's age, it is most likly a blown line or hose!
Sep 12, 2007 at 4:33 AM
Suggested Repair
Refill the empty front (large) reservoir with DOT 3 brake fluid and look for puddles or wet lines and hoses. On a truck this age, a sinking pedal with an empty front reservoir most likely means a blown brake line or hose rather than an immediate master-cylinder replacement.
Conversation Summary
The owner of a 1981 Ford Bronco with a 351M reported a brake pedal that sank more than usual, weaker stopping, and an illuminated brake light. The front reservoir compartment was empty while the rear remained full. The expert clarified that the large reservoir serves the front brakes and the small one the rear, and advised refilling with DOT 3 and checking for leaks. Given the truck's age, a blown line or hose was considered the most likely cause.
