The 4 speed overdrive transmission in my Bronco II is sometimes difficult to get into gear. The shifter had been removed and replaced and was loose on the transmission. Someone had stripped one of the capscrews so I replaced it. The fluid level was low and topping that off seemed to help but shifing into first gear still doesn't 'feel' quite right. Occasionally it crunches when I am placing it in that gear or feel spongy instead of positive when shifted into that position. The transmission is not noisy in operation and seems to function otherwise.
Any insights are greatly appreciated!
Thank you;
Evan Bennett
Thank you;
Evan Bennett
Nov 13, 2009 at 5:14 AM
