88 bronco 2 fuel system trouble
DLS65
Hope someone can help. Thing cranks after 2 or 3 attempts and runs fine. Turn it off for about 15 to 20 minutes and it won't crank. Wait hours and it will. No gas to the engine. Have replaced the pumps, filter, pressure regulator and relay. It seems that the gas pressure goes down to nothing after you turn it off. I'm no mechanic, just a regular gal trying to save money by NOT taking it to a mechanic again. Have heard may be a hole in the gas line and that is the only thing we haven't checked but it sounds like looking for a needle in a hay stack. Any and all help will be GREATLY appreciated !
Feb 2, 2006 at 10:07 PM
PAUL75
  • 8 POSTS
Before thinkin that the fuel line has a hole in it I would watch where my fuel gauge is before I turn the key off and then check it once I got into the vehicle and see where it is then.....You might want to have the injectors checked out some how...I am not guaranteeing it but I would try with that myself,I am also having a problem with my 86 bronco II so I know what you are going through with it.
Feb 3, 2006 at 4:13 AM
