1996 Ford Bronco Horn, Cruise Control, Air Bag Inflator Ind
1996 FORD BRONCO
06271948WH
Electrical problem
1996 Ford Bronco V8 Four Wheel Drive Automatic
The horn and cruise control stopped working on the steering wheel. At the same time, the air bag inflation indicator on the dash started blinking 3 times in sequence. At the same time, the temperature and direction in the overhead console stopped working. The horn will work with the remote entry switch. I've checked under dash for loose connections, and replaced the key switch. I've also checked the fuses and relays. One more thing. The voltage indicator on the dash does not come on some time, so I just give the top of the dash a good rap, and it starts working again. HELP!! Thanks. Wendell Herrington, Irvington, AL
Jun 7, 2010 at 3:22 PM
BMRFIXIT
  • 19,053 POSTS
Horn ,cruise control and air bag all relater to one point of intersection that is the clock spring under driver air bag in the steering column as for the dash ford have to suspect cluster or connection
https://images.2carpros.com/forum/automotive_pictures/99387_XgAdxjEKgDAMBdCAs1fpF8HF0SN4g2jFKtSWJFJw8Bje1U3wTetb__QQxcqmlmUglnugVKKyyymJrwdbk4RakkWbJHXRZElbwcMZJ4ZNEPjAOXdu1TeP2vBJ9_1.jpg
Jun 7, 2010 at 3:38 PM
