1990 Ford Bronco freeze plugs
1990 FORD BRONCO
PROFEP
Engine Cooling problem
1990 Ford Bronco V8 Four Wheel Drive Automatic
I can see were the water is dumping out. I recently was given a 1990 full size bronco. It still runs and drives. But I know that the freeze plug mounted behind the drivers side motor mount, what will it take too fix. And If I cant do it myself how much does this usually cost
Jul 8, 2008 at 5:29 PM
BLACKOP555
  • 10,386 POSTS
take off the wheel well to see if you can get to it better, or remove anything you can to get at it..
a shop can replace it for about 50-150 dollars by time you pay all the fees
Jul 8, 2008 at 9:41 PM
