1989 Ford Bronco blinker not working
1989 FORD BRONCO
140,000 MILES • 6 CYL • 4WD • MANUAL
BUNNICULAP
Blinker light not working all fuses are good. I can still hear the clicking sound and the dash board doesn't light up as well. Although the emergency light work outside as well as on the dash board. Any suggestions on what it is and how to fix it? Thanks
Mar 27, 2009 at 1:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty signal flasher. Your vehicle's turn signal flasher relay is located on the front of the fuse block..
Thanks for using 2CarPros.com!
Mar 27, 2009 at 1:20 AM
BUNNICULAP
Please be more specific. Thanks
Mar 27, 2009 at 1:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
A signal flasher is what allows your turn signals to operate properly. The symptoms you have described are caused by a faulty signal flasher.. The flasher (normally a silver round relay device) is located in the front seating area, driver side, driver side of steering column, under dash, mounted in the upper left corner of the fuse panel. You will need to replace the signal flasher by pulling it straight out of the fuse panel (much like removing a fuse) and then inserting the new signal flasher in its place. You can purchase the signal flasher at any local part store and it costs around $8 .
If you need further assistance just let me know.
Mar 27, 2009 at 1:36 AM
BUNNICULAP
Thanks a bunch... You saved me a lot of time and headache.
Mar 27, 2009 at 1:46 AM
