1974 Ford Bronco turn signals
BRONCO 74
  • 1974 FORD BRONCO
  • V8
  • 4WD
  • MANUAL
  • 30,000 MILES
I tore the bronco apart for paint, put it back together now my front turn signals do not work, the back is fine and the left side marker lights come on and the left front marker light signals as it should the right marker lights do not come on at all and the front turn signals do not work but the parking lights do work. I changed the flasher just to be sure but no luck. Any ideas?
thanks, john
updated 6/15/09
I tried running a new ground no luck, the parking lights work on the
front, just no turn signals, and like I said the left side lights come on and
work. Any other ideas? Thanks, John
Monday, June 1st, 2009 AT 4:46 PM
  • 109,885 POSTS
You must have caused a problem with the ground. Have you checked to see if there is power to the sockets? If there is, try running a seperate ground to make sure that isn't the problem.
Let me know what you find.
Thursday, June 4th, 2009 AT 9:46 PM
  • 109,885 POSTS
You had to break a wire at some point. Our schmatics don't go back that far. Can you get your hands on one?
Monday, June 15th, 2009 AT 7:49 PM
