1989 Ford Bronco Antifreeze in Windshield Fluid Reservoir
58,000 MILES • 6 CYL • 4WD • AUTOMATIC
PETERINCA
I accidentally poured some antifreeze into my windshielp wiper fluid reservoir. It's probably a 50/50 mix. Goofy mistake on my part. I would use a turkey baster to suck it all out and start all over but the reservoir appears to be sealed up. There is a sealed mesh like filter where you pour the fluid in.
Is this going to damage anything or will I just have funky washer fluid?
Nov 4, 2008 at 3:53 AM
DOCFIXIT
  • 18,828 POSTS
The mesh filter will pull out
Nov 4, 2008 at 5:00 AM
PETERINCA
Thanks for the answer. To be clear, are you saying there is some filter between the reservoir and the windshield that will dump 'non' windshield fluid?
Nov 4, 2008 at 1:04 PM
DOCFIXIT
  • 18,828 POSTS
If you pull hose off and drain
Nov 5, 2008 at 5:12 AM
