I just bought this truck. I am 17 and trying to fix it up. The guy that I bought it from told me what all was wrong with it and gave me all the parts to fix it. I have replaced all the freeze plugs and the motor is still leaking water from just behind and under the oil filter. I checked my freeze plugs both the one behind the motor mount and under the block. Do you have any suggestions?
SPONSORED LINKS
Monday, March 29th, 2010 AT 2:28 PM
MECHANIC
If you replaced the freeze plugs and they are not leaking, either you have a bad head gasket or a cracked engine block.
Check to see if you can tell if it is running down from the head.
