Steering problem
1989 Ford Bronco V8 Four Wheel Drive Automatic
the ignition upper actuator rod broke how do I replace it
Monday, November 23rd, 2009 AT 5:27 PM
BIGJIM79
MEMBER
I do believe it has two 5/16 shear bolts in it, if I remeber right. Lol remove or replace and insert same type of bolts.
SPONSORED LINKS
Wednesday, November 25th, 2009 AT 7:34 PM
RONDONAHUE
MEMBER
It does not have 2 5/16 bolts
Thursday, November 26th, 2009 AT 10:22 AM
BIGJIM79
MEMBER
Ok wrong type of column sorry. The ignition starter switch should be removed and this does require dropping the column. Once done you should be able to turn the key all the way past start and the rod or piece of rod should come right out. If not I'm stumped sorry.
