1988 Ford Bronco
DYLANJB1992
  • 1988 FORD BRONCO
Electrical problem
1988 Ford Bronco 6 cyl Four Wheel Drive Manual
STARTER ENGAUEGES WHEN YOU HOOK BATTERIES UP
Thursday, July 9th, 2009 AT 8:29 PM
BLACKOP555
  • 10,371 POSTS
Disconnect the +s terminall wire from the relay. If starter stops the ignitioin is sticking.
If nothing then the solenoid is bad and sticking causing the circuit to not turn off or starter is shorting to power. Very doubtfull on that as it takes ALOT of current to tun that baby.
Wednesday, August 12th, 2009 AT 8:14 PM
