Electrical problem
1987 Ford Bronco V8 Four Wheel Drive Automatic
I turned the ignition to start truck and now starter wont turn off even though the ignition switch is turned off had to take cable off of battery
Wednesday, December 30th, 2009 AT 2:15 PM
MERLIN2021
MECHANIC
Either the starter, or ignition switch, remove the starter, take it to the parts store, tell them what happened, they will test the starter, if OK replace switch, if starter in bad buy the new one. Ignition switch is the plastic block the harness plugs into, not the key cylinder!
