My Bronco is sick, it used to idle at 650rpm (in Drive).
Now it idles at 1250 rpm or 1000rpm or occassionally at 650rpm. Book says EFI has no idle adjust. I have just put cleaner in the tank with no improvement.
Wednesday, June 3rd, 2009 AT 11:15 AM
MECHANIC
Has the check engine light come on? Have you checked for vacuum leaks? It does have an idle air control valve and a throttle position sensor. If one is bad, the check engine light should come on.
