1987 Ford Bronco will not start with key
DJSCOTT
  • 1987 FORD BRONCO
Other Category problem
1987 Ford Bronco V8 Four Wheel Drive Automatic? Miles
I have just bought this bronco and it will not start with the key, if you turn the key on and jump the cilanoid it will crank and I have started it that way, I have put in new key cylinder and switch on the coloumn please help me. Thank you dj scott
Sunday, January 20th, 2008 AT 6:53 AM
BMRFIXIT
  • 19,053 POSTS
Check if your getting battery volts at the small switch wire at solenoid if you do solenoid no good
if not check the neutral safety switch on tranny or the wires leading to it
Sunday, January 20th, 2008 AT 8:55 AM
