1987 Ford Bronco Ran out of gas
88,000 MILES • V8 • 4WD • AUTOMATIC
87BRONCOGUY1
Ran out of gas now I cant even get the gas in the tank it just sit's at the top of the fill and when I put the cap on turn it over a few time's then take the cap off it blows the gas out the fill what is that what is the problem
Sep 10, 2009 at 6:11 AM
  • 110,248 POSTS
The only thing I can suggest you check is the breather. If you look under the truck where the filler tube goes to the fuel tank, you will see a smaller tube that runs along the filler tube. It is a breather that allows air to exit the tank as you fill it. IF it is plugged, can can't enter the tank.
Let me know what you find.
Oct 23, 2009 at 5:50 AM
