1987 Ford Bronco no spark
ALWAYSFIXINGIT
  • 1987 FORD BRONCO
Engine Mechanical problem
1987 Ford Bronco V8 Four Wheel Drive Manual
my? Is this bronco has power to the coil and has a constent power coming out of the coil wire to the cap but no spark whats wrong?
Friday, February 27th, 2009 AT 11:29 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, lets make sure I understand this.
You have 12v to the coil and you have spark going into the cap but no spark at the plugs.
If that is the case have you checked the inside of the cap for corrosion. If corroded replace both cap and rotor.
Friday, February 27th, 2009 AT 11:46 AM
