If it's just the one mount, you'll need a floor jack and a piece of 2x4 to use. Place the 2x4 on the edge of the oil pan so you can jack up that side of the motor. lift the engine until you have enough clearance to remove the old mount. (2 bolts hold it to the motor, 2 more hold it to the frame.) Bolt the new on the the motor 1st, then lower the jack until the mount is in place on the frame.
Jan 22, 2009 at 12:51 AM
