1987 Ford Bronco Fuel Problems..........
1987 FORD BRONCO
180,000 MILES • 6 CYL • 4WD • MANUAL
WERTHBILL
Just bought it! Ran for 2 days, then the next day it wouldn't start. It would turn over though. Checked to see if it was getting fuel, it wasn't. Let it sit a day then came back started right up drove it a day then it wouldn't start again. Installed a new fuel pump dropped the tank grounded the wire, new fuel filter inside tank new fuel regulator that wasn't it either. Tried fuel relay it does not go all the way down it is still about an 1/8 of an inch up. I don't know if that is ok or not, it is not getting gas that I know of, but why I cant figure out! We've tried everything what else could it be? The wires seem to be ok but I'm really not sure, any suggestions? Thanks!
Jan 29, 2008 at 11:45 AM
BMRFIXIT
  • 19,053 POSTS
[quote:adea5853a6="werthbill"]Other Category problem
1987 Ford Bronco 6 cyl Four Wheel Drive Automatic 180000 miles
Just bought it! Ran for 2 days, then the next day it wouldn't start. It would turn over though. Checked to see if it was getting fuel, it wasn't. Let it sit a day then came back started right up drove it a day then it wouldn't start again. Installed a new fuel pump dropped the tank grounded the wire, new fuel filter inside tank new fuel regulator that wasn't it either. Tried fuel relay it does not go all the way down it is still about an 1/8 of an inch up. I don't know if that is ok or not, it is not getting gas that I know of, but why I cant figure out! We've tried everything what else could it be? The wires seem to be ok but I'm really not sure, any suggestions? Thanks![/quote:adea5853a6]
bronco v8 or broncoII v6
if full size bronco
I think you have another fuel pump on the frame rail under the driver check if you do and if its working
broncoII check
Jan 29, 2008 at 12:05 PM
