1986 Ford Bronco won't start
MARKDILLARD
  • 1986 FORD BRONCO
  • 6 CYL
  • 4WD
  • 165,000 MILES
Razamataz responded to previous. Have you ever seen a fuel pump go out in the middle of driving without warning? Also I just replaced water pump a couple of hours before. I noticed a vacuum leak somwhere while I was driving, and it was idleing higher. I was wondering if I could have loosened a wire to a sensor or vacuum line to somthing that would have shut down the fuel pump? I'll be glad to donate as soon as my check is marked up in my bank tomorrow.
Thursday, September 18th, 2008 AT 12:09 PM
To answer the question I do-could be the computer/a failing inertia switch did you checked the items I've mentioned.
Or it could be the ICM
Do you hear the fuel pump come on-if so check fuel pressure if its within specifications then its something else
Thursday, September 18th, 2008 AT 2:42 PM
