1986 Ford Bronco
GUSSVOLK
  • 1986 FORD BRONCO
Transmission problem
1986 Ford Bronco 6 cyl Four Wheel Drive Automatic
ford bronco 2 1986 push button 4x4. The push button does nothing when I push it. Worked fine last use. Where should I start my trouble shoot
Tuesday, December 30th, 2008 AT 4:34 PM
  • 109,885 POSTS
Hi:
Start by checking if there is power to the actuator at the transfer case. Have a helper push the 4wd buttons while you check. If there is power, the actuator is most likely bad (not uncommon).
Let me know if this helps.
Sunday, January 4th, 2009 AT 2:17 PM
