1986 Ford Bronco AC Not Working
TSTEPHENS
I found a 1986 Ford Bronco (Eddie Bauer-Inj V8-4X$) w/84,000 miles on it for my son. The AC doesn't work & they said we would have to change everything out because it is the old style & will be about $850. Will AC parts off of newer Ford pickup work?? (Like from a wrecking yard?)
Jun 26, 2007 at 4:08 AM
MERLIN2021
  • 17,250 POSTS
How handy are you? You can buy a kit for about 50-75 dollars to convert it to R-134a, the new refrigerant. Go to a good parts supply store.
Jun 26, 2007 at 9:05 AM
TSTEPHENS
I'm not a mechanic - but pretty handy with tools. They also told me the compressor is bad (leaking out). That is another reason about asking if other years will interchange????
Jun 27, 2007 at 1:16 AM
MERLIN2021
  • 17,250 POSTS
You can go to the junk yard and ask...they have an interchange book and can tell you!
Jun 27, 2007 at 7:36 PM
Suggested Repair
Use a parts-store R-134a conversion kit (about $50–$75) for the older system. Because the compressor is leaking, ask a junkyard to check its interchange book for a compatible compressor or other AC parts rather than assuming newer Ford pickup parts fit.
Conversation Summary
The owner of a 1986 Ford Bronco with a nonworking AC was told the old-style system would need a full replacement costing about $850 and asked whether newer Ford pickup AC parts from a wrecking yard would fit. An expert suggested a low-cost R-134a conversion kit from a parts store. After the owner noted the compressor is leaking, the expert advised asking the junkyard, which has an interchange book, about compatible parts.
