1982 Ford Bronco rough running
130,000 MILES • 6 CYL • 4WD • MANUAL
KEVINJRGASTON
  • 17 POSTS
Its runnimg like its missing on one cylinder. I replaced the spark plugs and coil as well as the the carb. It was running with a little too mich oil, so i drained some of it out hoping that would keep it from burning whatever would cause it to burn a white smoke. I allso repla'ed the intake/exhaist m!ifold gasket. Any ideas what the problem is?
Apr 21, 2010 at 7:04 AM
  • 110,251 POSTS
If you are getting white smoke from the exhaust, chances are you have a bad head gasket. White smoke is usually from coolant burining in the combustion chamber. Check to make sure the coolant isn't mixing with the engine oil and oil isn't getting into the coolant. Also, you should check engine compression to see if there is a weak cylender.
LEt me know if you have other questions.
Apr 24, 2010 at 2:08 PM
KEVINJRGASTON
  • 17 POSTS
I was thinking it was either that or a bend/pinched fuel line, since it has the steel lines from pump to carb..
Apr 26, 2010 at 5:16 AM
  • 110,251 POSTS
It could be a fuel pump problem, but if you have white smoke, chances are good it is a headgasket.
Apr 26, 2010 at 5:24 AM
KEVINJRGASTON
  • 17 POSTS
Well, once I got the gasket replaces i notices it was trying to start ang would backfire. the carb would also pop and it seems like a grey smoke would come out of it. Any ideas? Maybe spark plugs or wiring?
Apr 30, 2010 at 6:55 AM
  • 110,251 POSTS
Which gasket are you refering to? Have you checked timing?
May 1, 2010 at 6:45 AM
