1982 Ford Bronco Not starting right
110,000 MILES • V8 • 4WD • MANUAL
COREYANDREWSCOTT
I just bought a 1982 ford bronco and i test drove it twice befor i bought it. Every time i stared it befor i bought it, it started every time with out a problem. I bought it drove it home it was a 50 mile drive. I get home shut it off and 5 mins later i try to start it and it wont start. I let it sit overnight and it took 4 or 5 times and it started agin and i drove it for 10 mins and broght it back home and it wont start agin. It will turn over but it wont fire.
Feb 18, 2009 at 1:31 PM
BLACKOP555
  • 10,386 POSTS
when it wont start, check the fuel pressure and check for spark on ALL cylinders..
does it start with gas dumped in throttle body?
Feb 22, 2009 at 1:49 AM
COREYANDREWSCOTT
I am assuming it is some kind of electrical problem, because i can smell gas while tring to start it. I have changed a lot of electrical parts so far including the crankshaft position sensor, plugs and wires, ignition manifold, and coil. What would make it start everyonce in a while other than that? Loose wire, bad connection, bad wire. How should i check the fuel pressure? Thank you for your support.
Feb 24, 2009 at 4:40 PM
