1977 Ford Bronco rough idle...smooth at high rpms
177,000 MILES • V8 • 4WD • AUTOMATIC
KROWENS76
  • 6 POSTS
This just started yesterday leaving work. Engine will run rough when ideling(when I say rough, I mean it shakes the whole truck), but as soon as you give it enough gas either driving or in park it smoothes out. The engine doesn't die, but seems as though it wants to. I rebuilt the carburetor 6 months ago and adjusted the timing..and it has run perfect until this point. The engine was recently rebuilt 1 yr ago as well and the following replaced: New spark plugs, wires, cap, rotor, coil, fuel filter, fuel pump.
The temperature has just recently dropped a considerable amount as well (-20°), not sure if that impacts any thing. Another thing I recently noticed is that if I punch the gas, every once in awhile the engine will backfire. This is my daily driver..please help!
Oct 28, 2008 at 1:43 AM
DLOBI
  • 125 POSTS
That sounds an awful lot like a vacuum leak. Did any vacuum hoses fall off, fail, get bumped ? There is a lot of vacuum in the manifold at idle and little to none as your rpm gets high thus the possible reason it smothes out. Get under the hood with it idling and listen for the vacuum leak.
Oct 28, 2008 at 1:47 AM
KROWENS76
  • 6 POSTS
I tried that..the whole engine is loud and it is hard to tell. Is there another solution to finding a leak? maybe soapy water? The colder weather wouldn't affect the idle. Resulting in adjusting the carburetor for the change in temperature? Also, would it be beneficial to upgrade to a edelbrock 600 cfm to improve performance?
Thanks!
Oct 28, 2008 at 1:54 AM
DLOBI
  • 125 POSTS
There are a couple of methods for finding a vacuum leak. Spraying some carb cleaner that can get sucked in the leak will quickly change rpm and let you know. You also can try with a length of hose with one end up to your ear like a stethescope. Move the other end around and you will hear more localized noise this way. Listen for a sucking air sound.
Oct 28, 2008 at 2:05 AM
KROWENS76
  • 6 POSTS
I have to get to and from work...is this harmful to my engine to drive until I get it figured out?
Also, would a 600cfm edelbrock carb be a beneficial upgrade? from a performance standpoint?
Thanks
Oct 28, 2008 at 2:39 AM
