1993 Ford Aerostar RABS Module Replacement Fix
THEX691
I have a 1993 3 liter Aerostar with 93,000 mi. that has an issue in the ABS Rear Barake Sensor. I have had the system checked at a garage and they found now problems in the lines from the Master Cylinder to the rear cylinders. After inspection, I was told that it is an issue in the Control Module. I found the part in a local parts store and want to replace it. Will I have to go through and run an entire brake bleed when the module is replaced? I would think that I would not have to considering there is no line that goes into the back of the controler. It should just be the plug that goes into the module that regulates the Hydrulic Unit, correct?
Sep 25, 2007 at 3:33 PM
MERLIN2021
  • 17,250 POSTS
The RABS just bolts on to the differential, plug in connector and your good to go!
Sep 25, 2007 at 7:50 PM
Suggested Repair
Replace the RABS module by bolting it to the differential and connecting the plug-in connector. A full brake bleed is not required.
Conversation Summary
The owner of a 1993 Ford Aerostar was told the rear ABS control module was faulty and asked whether replacing it requires bleeding the brakes. The expert said the RABS unit simply bolts to the differential and uses a plug-in connector, so no brake bleed is needed.
