My van was in an accident and now the engine will turn over but won't start. It also doesn't have any fuel pressure. Can you help me?
Aug 26, 2007 at 1:48 PM
Check and reset the fuel pump inertia cutoff switch, which is designed to shut off fuel after a crash to prevent a fire.
The owner of a 1989 Ford Aerostar said the van was in an accident and now cranks but will not start, with no fuel pressure. The expert advised checking the fuel pump inertia cutoff switch, which cuts fuel after a crash.
