1997 Ford Aerostar oil pressure
1997 FORD AEROSTAR
212,000 MILES • 6 CYL • AWD • AUTOMATIC
PGERLA
Over the last few months, I noticed that the dashboard gauge shows a change in oil pressure. At times, especially after a long drive, the pressure will drop and remain low (and stay constant) until the engine cools down and is restarted. Starting the engine again, the pressure will be back to where it always had been. At all times, however, the gauge shows that the pressure is in the "normal" range, but I am concerned that there may be a incipient problem with the oil pump or pressure regulator. Oil level is fine. We have a long trip planned in the near future.
Dec 13, 2007 at 11:42 PM
  • 31,937 POSTS
Hi there,
Have the oil pressure tested with a master gauge, this will screw in where the pressure sender fits and will give a true pressure reading. When you know what the hot idle pressure is, check with the specifications for your car, as it has done a considerable number of miles, i would be considering worn engine bearings, tired pump and pressure relief valve.
Mark (mhpautos)
Dec 14, 2007 at 3:01 PM
